Under the hood, it’s a custom WebGPU path tracer running directly on the GPU in your browser. It combines physically based lighting and reflections, realistic glass refraction, AI denoising, and adaptive resolution for responsive navigation—even with complex CAD models. The core rendering shaders and geometry pipeline were built specifically for this engine.
I am not aiming to take on any renderer, but after 20 years of using, discussing and reading up on rendering technology, I got tired of waiting on a solution that actually does what I know is possible, in a way I would enjoy using it. So I started this project. And I really enjoy the process of directing, testing and evaluating, reflecting and redirecting in a fluid and fast way. The user base is just me, and my imaginary friends
The weekend was spent digging ditches to move the power grid from poles into the ground, so about 12-13 hours of physical work each day, so I needed some mental relief at the evening
And I really enjoy modelling, coming from close to 20 years of industrial design, now focusing on landscape architecture, I need to model some well shaped products every now and then. And give them the opportunity to shine. Rhino has come quite a long way in fascilitating this, but some caveates were never addressed, like ease of use, time-to-market and inspiration. So I wanted to see if I could build something to inspire that. If you want to give it a spin I’ll set up a temporary login for you to test and follow along on the development. I have no idea about when it will end up on the shelf though, or if it will mature for a long time.
The latest integration is a fast denoiser (Intel small fp16 ODIN that just adds 0,6MB to the startup load) so now I get results like this in about 1 second on only 10 passes:
(Scene built to evaluate HDRI’s from PolyHaven to see that we handle them correctly, after a few tweaks it became good enough)
I have explored dispersion and caustics too, but that will take time to implement correctly. As this is a user-first project and not a tech demo.
This is what your great Iron looks like. Basically right out of the box. I just dropped your Rhino file in, chose the second included HDRI, rotated the HDRI and key light, tweaked their intensity and adjusted the camera exposure a bit. Setup and render less than two minutes. Materials are as they came from the Rhino model I had tweaked.
(Edit: Model courtesy of
@CADARTZ, I forgot to write that since it was a direct response to his comment, but that’s not obvious to anybody else, so there you go: That great model was made by mr. CadArtz.)
