I want to check if an InstanceDefinitonGeometry in a File3dm object is linked to any external file or not, and if at all it is, then get the path of the external file. Is there a way to do this?
For example, InstanceDefinition class has a property called InstanceDefinition.SourceArchive, but there is no such property for InstanceDefinitionGeometry.
Thanks.
Hi @Darryl_Menezes,
Keep in mind that the geometry linked instance definitions is not stored in the target .3dm file. Thus, if you find a File3dmObject
whose ObjectAttributes.InstanceDefinitonGeometry
attribute property is true
, then the instance definition is either InstanceDefinitionUpdateType.Static
or InstanceDefinitionUpdateType.LinkedAndEmbedded
In any case, the InstanceDefinitionGeometry
class, which is the File3dm
of an InstanceDefinition
, does not expose enough stuff for you to determine any of this. I’ve created a YouTrack item to beef this class up a little.
https://mcneel.myjetbrains.com/youtrack/issue/RH-51399
– Dale
