Hi all,
I have two lists of different surfaces and I am trying to determine if any surfaces are repeated in both lists. For that, I am trying to compare their centroids with little tolerance of 20 cm. I am using Closest Point for Brep to use distance for culling the points.
However, this approach is not working for me. I believe it may be due to flattening or grafting (different list length) and I have tried all possible scenarios but it did not go through.
Could you please have a look and suggest some solution?
Thank you so much!
PointsInside.gh (28.1 KB)
