Checking onAdd Event Source
Hi @dale, Is it possible to check what fires onAdd event listener with Rhinocommon? I want to check if onAdd event occurred because of “importing objects into the document” or “copying an object in the document”. Thanks!
Sure - just make a test command that listens to the “OnAdd…” event.
You can also build and run this example:
– Dale
Hi @dale , I guess I couldn’t explain the situation. I created a listener for onAdd event and both actions (importing objects to document and copying an object in the document) fires the listener. I want to know if listener fired from “importing” or “copying”. I hope it is more clear now. Thanks!
When import a file, a RhinoDoc.BeginOpenDocument event will be triggered with the DocumentOpenEventArgs.Merge property set to true. This occurs before any RhinoDoc.AddRhinoObject event.
– Dale
Hi, Thanks a lot! Listening OpenDocument events solved the issue.
static bool isImporting = false;
internal static void onEndOpenDoc(object sender, DocumentOpenEventArgs e)
internal static void onBeginOpenDoc(object sender, DocumentOpenEventArgs e)
      isImporting = e.Merge;
