I would like this (only better)
It is immediately obvious if the boolean is set or not. It is one click to change.
I don’t mind that it makes the component wider.
You have invert option there. Which pretty much do the tick box thing.
Cheers,
BVR
The default option shouldn’t make the component bigger, ofc default depends on component, but if you know what the default is and then use invert in your code it’s pretty obvious.
