import Rhino
import scriptcontext as sc
def test_azure():
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select first curve")
go.GeometryFilter = Rhino.DocObjects.ObjectType.Curve
go.Get()
if go.CommandResult() != Rhino.Commands.Result.Success:
return go.CommandResult()
curve0 = go.Object(0).Curve()
if not curve0:
return
go.SetCommandPrompt("Select second curve")
go.EnablePreSelect(False, True)
go.DeselectAllBeforePostSelect = False
go.Get()
curve1 = go.Object(0).Curve()
if not curve1:
return
tol = sc.doc.ModelAbsoluteTolerance
ccx_events = Rhino.Geometry.Intersect.Intersection.CurveCurve(curve0, curve1, tol, tol)
if not ccx_events or 0 == len(ccx_events):
print("No intersectons found")
return
for i in range(0, len(ccx_events)):
ccx = ccx_events[i]
if ccx.IsPoint:
print("Event[{0}] type = Point".format(i))
elif ccx.IsOverlap:
print("Event[{0}] type = Overlap".format(i))
if __name__ == "__main__":
test_azure()
import Rhino
def find_overlapping_curves():
go.SetCommandPrompt(“Select first curve”)
go.Get()
curve_in0 = go.Object(0).Curve()
if not curve_in0:
return
go.SetCommandPrompt(“Select second curve”)
go.Get()
curve_in1 = go.Object(0).Curve()
if not curve_in1:
return
Cur1=rs.ExplodeCurves(rs.coercecurve(curve_in0),False)
Cur2=rs.ExplodeCurves(rs.coercecurve(curve_in1),False)
overlaps =
rs.UnselectAllObjects()
for curve0 in Cur1:
rs.SelectObject(curve0)
for curve1 in Cur2:
rs.SelectObject(curve1)
ccx_events = Rhino.Geometry.Intersect.Intersection.CurveCurve(rs.coercecurve(curve0),rs.coercecurve(curve1), tol, tol)
if ccx_events or 0 != len(ccx_events):
ccx = ccx_events[i]
if ccx.IsPoint:
print(“Event[{0}] type = Point”.format(i))
elif ccx.IsOverlap:
overlaps=[curve0, curve1]
Cur1.remove(curve0)
Cur2.remove(curve1)
break
rs.UnselectObject(curve1)
rs.UnselectObject(curve0)
rs.DeleteObjects(Cur1)
rs.DeleteObjects(Cur2)
return overlaps
if name == “main”:
Can’t check your code as you’ve only provided screenshots and unformatted text.
If you check the geometry closely in the file you provided, you can see that the segments you indicated do in fact have a very small overlap (approx. 6E-11 units).
