I dont know if the link will work but when I’m trying to booleanunion the parts and then I do Check it says not valid
Hello - please post a file with the input objects before the Boolean operation. From here, your link above does not work…
{"error":401,"message":"Unauthorized"}
Im trying to upload the file but it loads to 100 and then nothing happen
Done
Hello - - try this:
SelBadObjects
. Invert Hide
ExtractBadSrf
You’ll see where the problem is - you can fix it up by re-trimming the relevant surfaces by hand…
- Delete the surface that looks like a circle.
Untrim
the conical surface. -
ExtractSrf
the outer surface and the small cylinder. -
Untrim
the hole in the outer surface - ExtendSrf the cone a little.
- Use all of these surfaces to trim things back to the correct arrangement.
highwayringunboolean_PG.3dm (700.5 KB)
the left one failing when I do booleanunion, the rest booleanunion just fine
Hello - you do not say what you are unioning to what - here, if I replace the bad object in your file with my repaired version, all the ring parts can be Unioned into one.
I do wanna union all the pieces into one piece and when I do so, it gets not valid
thank you got it.
really helped me
