Check if two boundingboxes intersects/collides
Is there a faster way to check if two boundingboxes intersects/collides than converting those bboxes to meshes and using meshmeshfast:
Rhino.Geometry.Intersect.Intersection.MeshMeshFast
I just need true and false output.
Just compare Min and Max of both bounding boxes, mathematically.
This is a fastest way.
Got it thanks:
bool Intersects(BoundingBox current, BoundingBox other) {
return
(current.Min.X < other.Max.X) && (current.Max.X > other.Min.X) &&
(current.Min.Y < other.Max.Y) && (current.Max.Y > other.Min.Y) &&
(current.Min.Z < other.Max.Z) && (current.Max.Z > other.Min.Z);
We had a thread on this topic that might be useful here as well (for non-world orientated boxes etc):
Is non-world oriented boxes can be called bounding boxes?
I have a question of this because bbox is generally defined by min and max point.
You can get/calculate bounding boxes aligned to any plane using this overload (a good approach in 2.5D is to run it with a number of samples, incrementally rotating the plane N times, and then returning the smallest box):
http://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_GeometryBase_GetBoundingBox.htm
