I made a command that does some tasks.
I need check if this command is runing or not, there some way?
like:
RhinoApp.RunScript("_-Custom",true);
If (command (_-Custom== true)
messagebos.show(“Command is running”);
like:
Hi @MatrixRatrix
See the EndCommand event in the sample https://github.com/mcneel/rhino-developer-samples/blob/6/rhinocommon/cs/SampleCsEventWatcher/SampleCsEventHandlers.cs
There are several static functions on the Command class in RhinoCommon to check active command and the command stack.
You probably want
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Commands_Command_InCommand.htm
or
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Commands_Command_GetCommandStack.htm
Thank you.
