How can I check if certain sticky value exists or has value to avoid certain errors.
if sticky(object) exists:
delete object
else:
sticky = new object
delete object
else:
sticky = new object
Hi @ivelin.peychev, you might try to use has_key
as shown below:
import scriptcontext
key = "Rhino"
if scriptcontext.sticky.has_key(key):
print "Key '{}' exists in sticky".format(key)
else:
print "Key '{}' was not found in sticky".format(key)
_
c.
Thanks @clement,
The behavior is the same as my script, I assume it’s not the sticky but the deleting of the clipping plane that causes this exception.
I opened another thread to keep this clean only for the sticky
