Changing the bolt properties of tekla object
Hi All,
Is there a way to change the bolt properties of tekla object using grasshopper?
For example changing the bolt diameter or bolt x and y distance or the position on plane?
Thank you.
Hi Robert,
You can’t really affect bolts at the moment. With a C# component modifications could be implemented though, if you’re inclined to that.
Cheers,
-b
Hi Sebastian,
Thank you for the response.
Hopefully in the future we can have modify component for bolts also.
