Changing Text Style in Revit Using Rhino.Inside
I’m looking for a way to update the text style across an entire Revit document, including all families, changing the font from Arial to Arial Narrow. Instead of manually opening each loadable family, changing the text type within the family, reloading, and overriding in Revit, is there a way to achieve this automatically using Rhino.Inside?
This would require a bit of work via RiR.
There are Revit addins, such as:
Hi Japhy,
Thank you for the suggestion. However, due to our company’s installation restrictions, particularly considering the developer’s location, we are unable to proceed. I will need to explore alternative solutions.
