Changing direction
Hi , How can i change graph direction of curve to z+ direction (one direction), example for top surface of gems to align in the same direction
resim
If you are using ArrayCrv to distribute the gems, use the Orientation=NoRotation option to keep all the gems aligned in the same direction.
Thank you : ) ,using any app or macro for rhino , I think that Rhino uses with compute graph of curve.
