jeremy5
(Jeremy)
1
If you change the display settings for curve width from the default ‘Use object’s width’:
to a large pixel value:
and then back to the default, Rhino resets but Grasshopper remains stuck with the pixel value:
You have to set a low pixel value first before changing to the ‘object’s width’ option.
jessesn
(Jessesn Chen)
2
Thank you for your report, and I’m seeing this issue as well. I have logged it with our development engineers.
RH-93601 Display: Changing curve width in Rhino can leave GH curve width stuck
brian
(Brian Gillespie)
3
RH-93601 is fixed in Rhino WIP
