Problem found in Rhino Version 8 SR23 (8.23.25251.13001, 2025-09-08):
When changing the color via Properties on a sub-selection of multiple BrepFaces, the Brep names are overwritten and replaced with the name of one of the affected Breps.
This is a temporary fix for me for now:
public class CmdSetBrepFaceColors : Command
public override string EnglishName => "SetBrepFaceColors";
// 1) Select faces (subobject select)
GetObject go = new GetObject();
go.SetCommandPrompt("Select Brep faces to change color");
go.GeometryFilter = ObjectType.Surface;
go.SubObjectSelect = true;
go.GetMultiple(1, 0);
if (go.CommandResult() != Result.Success)
return go.CommandResult();
// 2) Choose color
Color color = Color.Red;
if (!Dialogs.ShowColorDialog(ref color))
return Result.Cancel;
// 3) Collect face indices per object
var facesPerObject = new Dictionary<Guid, List<int>>();
for (int i = 0; i < go.ObjectCount; i++)
ObjRef objRef = go.Object(i);
BrepFace face = objRef.Face();
RhinoObject rhObj = objRef.Object();
if (face == null || rhObj == null) continue;
Guid id = rhObj.Id;
if (!facesPerObject.ContainsKey(id))
facesPerObject[id] = new List<int>();
facesPerObject[id].Add(face.FaceIndex);
// 4) Per object: duplicate geometry, set face colors, replace in doc
foreach (var kvp in facesPerObject)
Guid objId = kvp.Key;
List<int> faceIndices = kvp.Value.Distinct().ToList();
RhinoObject rhObj = doc.Objects.FindId(objId);
if (rhObj == null) continue;
GeometryBase geom = rhObj.Geometry;
Brep newBrep = null;
if (geom is Brep brep)
newBrep = brep.DuplicateBrep();
else if (geom is Extrusion ext)
newBrep = ext.ToBrep();
if (newBrep == null) continue;
// Set PerFaceColor
foreach (int fi in faceIndices)
if (fi >= 0 && fi < newBrep.Faces.Count)
newBrep.Faces[fi].PerFaceColor = color;
// Replace object in doc, keep attributes (including name)
bool ok = doc.Objects.Replace(objId, newBrep, rhObj.Attributes);
if (!ok)
RhinoApp.WriteLine($"Failed to replace object {objId}");
doc.Views.Redraw();
return Result.Success;
Same in Rhino 9 WIP
object-name-issue.3dm (158.9 KB)
System Info
Rhino 9 SR0 2025-9-23 (Rhino WIP, 9.0.25266.10145, Git hash:master @ 20b4067c1882a571b5304975d8b2385b4678fada)
License type: Commercial, build 2025-09-23
License details: Cloud Zoo
Expires on: 2025-11-07
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 128GB)
.NET 9.0.9
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 8-21-2025 (M-D-Y). DirectX(11)
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 8-21-2025 (M-D-Y).
- There are no monitors attached to this device!
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.29 DYNAMIC_ARCH NO_AFFINITY Zen MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\import_PLY.rhp “PLY - Polygon File Format Import”
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\ShrinkWrap.rhp “ShrinkWrap” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\import_STL.rhp “STL Import”
C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
RH-89667 is fixed in Rhino 8 Service Release 25
