I have a STEP file created in top view in Solidworks, in Rhino it opens as the front view, how do I change this to be the top view
Hi Cathi - you can’t change the default view orientations but you can rotate the objects so that they match the SW view, though be careful since they will no longer match the SW coordinates.
Select the model and Rotate
in Right on the origin 90 degrees. Or use a macro like this one for Rotate3D
! _All Rotate3d 0 1,0 90
Thnak you, this worked perfect for me
