In ApplyMeshInstanceChanges when running in v8, MeshInstance.GroupId seems always to be UInt32.MaxValue, and MeshInstance.MeshIndex seems always to be 0.
I have used GroupId/MeshIndex in v6 & v7 for identifying when separate meshes given to the ChangeQueue are part of the same logical mesh (e.g. 6 faces given for what the user sees as a box extrusion, and what I must export as a single mesh), and implementing sub-object materials.
Though the various IDs on MeshInstance are documented, it is not clear what the documentation actually means. i.e. what is a MeshInstance ancestry, and what do the various RootId/ParentId/GroupId/MeshId properties actually represent, so I do not know if I might be able to use some combination of them in lieu of GroupId/MeshIndex, or whether it is an oversight that GroupId/MeshIndex are not being set as before.
Below are the results of printing the values of these properties in v7 and v8, for a file containing a box extrusion with sub-object material assigned to the top face.
RootId/ParentId are not present when running in v6, and in v7 the RootId matches the MeshId, and is the same for all faces, with GroupId also being the same for all faces, while the ParentId is just Guid.Empty. MeshIndex returns indexes 0-5 as expected for each face.
In v8, RootId remains consistent for all faces of the box, and matches the RootId from v7, but MeshId is different for each face, GroupId returns UInt32.MaxValue for all faces (not just for one box, but for every mesh in the model, apparently), and MeshIndex returns 0 for all faces (also for every mesh in the model).
box extrusion in v7:
RootId: 962f5b09-f369-4a1b-851f-1450bfe74192
ParentId: 00000000-0000-0000-0000-000000000000
GroupId: 1262210833
InstanceId: 614957360
MeshId: 962f5b09-f369-4a1b-851f-1450bfe74192
MaterialId: 140370497
MeshIndex: 2
GroupId: 1262210833
InstanceId: 2619074133
MeshIndex: 3
GroupId: 1262210833
InstanceId: 3111172489
MaterialId: 2921531358
MeshIndex: 5
GroupId: 1262210833
InstanceId: 30203628
MeshIndex: 4
GroupId: 1262210833
InstanceId: 2393786811
MeshIndex: 0
GroupId: 1262210833
InstanceId: 907161310
MeshIndex: 1
box extrusion in v8:
GroupId: 4294967295
InstanceId: 238399426
MeshId: 39e4820c-d421-49b1-b334-b3cac4b722c4
MaterialId: 3482931093
MeshIndex: 0
GroupId: 4294967295
InstanceId: 2333606099
MeshId: d9d4faf1-5cf7-472f-89bd-2d5e7026a329
MeshIndex: 0
GroupId: 4294967295
InstanceId: 2422992428
MeshId: 98a57787-91ee-41a4-b75f-2b4da5b93f5b
MeshIndex: 0
GroupId: 4294967295
InstanceId: 2111537023
MeshId: 41bb8a9e-c43a-4c0c-8d2a-c6a2b3fb539f
MeshIndex: 0
GroupId: 4294967295
InstanceId: 3767030726
MeshId: 8b35d795-f07a-4147-a750-f5be4023f84c
MeshIndex: 0
GroupId: 4294967295
InstanceId: 3995626916
MeshId: e9240e45-5ec8-4dc5-aa96-5c4314fdacd4
MaterialId: 628958114
MeshIndex: 0
