If there is a linked block in the file with the the same layername as in the main file, the ChangeLayer command doesn´t work.
Anyone with the same behavior?
Regards,
Thomas
Regards,
Thomas
Hi Thomas- do you mean it fails completely or it fails to move objects in the linked blocks to a different layer?
What I mean is when I:
Select an object in the current file (not in the linked block)
Type -ChangeLayer “-4-” (<-- layername)
The object isn’t changed to the layer “-4-”
This only happens when a specific layer is also included in a linked block.
Regards,
Thomas
Hi Thomas- thanks… I cannot reproduce this here so far-
-ChangeLayer "Layer Name"
to another layer in the current file……works fine. Is that the right test for what you are seeing? Does it happen in any file?
thanks,
Hi pascal,
I reproduced it again and it won’t work still.
I can change layers of course, but not if the same layer name is also in the linked block.
Here is an example main file and a linked block.
Try to place the long box in the 4 layer with -changelayer 4.
It does work if I select the layer, RMB, select Change Object layer. But not with -Changelayer.
If I make a new layer 5 is also works. But if the layer already is in the linked block it won’t…
Example.rar (24.1 KB)
Yes, OK, I see. Thanks, I’ll see if this can be fixed.
http://mcneel.myjetbrains.com/youtrack/issue/RH-29890
