Change width of docked panel - cursor position tolerance is too tight
The tolerance for positioning the cursor to change the width of a docked panel is too tight.
Selecting the icon for adjusting the width of a docked panel is very sensitive. I seems that the cursor needs to be position within one or two pixels to select the icon. If the cursor is not within this narrow band either nothing is selected, which is tolerable, or the “move panel” icon is selected instead, which is very undesirable as it can result in undocking the panel.
To adust the width of the docked panel I have to very carefully move the cursor so that the appropriate icon appears, then hold the cursor steady until I left click to make the adjustment.
I had this fixed at some point, but it broke several other things, unfortunately, and had to be reverted. It’s still an open issue.
The easy way to fix this is to increase the borders visually, which looks really bad.
