I’ve noticed that I can’t select a face on a polysurface with this method like I could in V5.
This video will explain it better.
Thanks,
Dan
Thanks,
Dan
@DanBayn
Without an accurate category assignment, it’s not likely the developers will not see this post.
I was having this problem too, so I managed to write it as shown below, to get my script to determine the surface face of a polysurface, to use as the surface object in rs.GetPointOnSurface. It is a problem with the rs.GetObject not extracting the individual surface from the polysurface, to be able to be used as the input surface for rs.GetPointOnSurface. I say this too, as in the case of a filter, not allowing the selection of a surface in a polysurface, through the python method of object filtering.
objref = Rhino.Input.RhinoGet.GetOneObject(“Select Brep Face”, False, Rhino.DocObjects.ObjectType.Surface)
surface = objref.Surface()
surfaceId = objref.ObjectId
I thought this was the right category since it affects scripting in V6. Which category would be more appropriate?
Thanks,
Dan
Thanks Colby. I’ll try this and see if I can make it work.
Dan
It is now.
Your original listing had no category assigned.
Thanks John, I was being called to another building just as I was posting that so I guess I overlooked it. Too many things happening at once!!!
Hi Dale,
Yes, that’s it. The Box command creates an extrusion, and that’s what I was using to test. If I convert to a polysurface it works as it should.
I will have to remember to convert before using this method.
Thanks,
Dan
Hi @DanBayn,
This does work differently than RhinoScript. I’ve logged an issue on this.
https://mcneel.myjetbrains.com/youtrack/issue/RH-41529
– Dale
Thanks. I can’t view the log, so I’m curious if it’s the Box command making an extrusion or the GetPointOnSurface method that doesn’t work on extrusions that needs fixing.
