Change the output based on a condition
I’m trying to write a Python script so that the output changes depending on a specific condition.
I created a node using Python.Py3 (I’m using Rhinoceros 8).
I created 4 inputs:
A, B, C, and D.
A is a list of points.
B is a list of points.
C is a value to compare.
D is a value to compare.
If C is equal to D, the output should be the list of points that go into A.
If C is not equal to D, the output should be the list of points that go into B.
I’m having no success doing this.
I might not even need Python for this, but I don’t know how.
The script I created was this:
import ghpythonlib
# A, B are Tree Access
# C, D are Item Access
# 1. Function Definition
def select_list(A, B, C, D):
try:
    C_val = C
    D_val = D
except:
    C_val = C
    D_val = D
\# Lógica de seleção
if C_val == D_val:
    \# Return Data Tree B
    return B
else:
    \# Return  Data Tree A
    return A
# 2. Call the function and assign the result to the standard output variable
# Use ‘a’ or ‘out’ depending on how you named the component’s output!
# I’ll use ‘a’ as the default to avoid confusion.
a = select_list(A, B, C, D)
Change_the_output_based_on_a_condition.gh (7.9 KB)
This is what Stream Filter is for
(note that you can zoom in on the Filter component to add more inputs, but then you need to feed it a non-binary Gate value, which is not always straightforward)
Stream Filter.gh (7.0 KB)
Thank you very much
