Change the Family Parameter
Hi, I am curious that if there is a way to change the value of a “Family Parameter”. I am able to define a parameter to a family, but the value of it fails to be changed by the “Element Parameter” node.
Thanks!
If you could share the family file, we can examine it.
Btw, if its a Type Parameter, you should connect Element Type just before Element Parameter node.
Hey MT, problem solved but adding the Element Type. Thanks!
