Change the colormode of ViewCapturetoFile
Is there a way to change the colormode of command “ViewCapturetoFile” ?
So that I can choose to output a BlackAndWhite, PrintColor or DisplayColor?
Colormode setting is currently unaccessible through adding - in front of the command.
But I think it is a manipulable setting.
https://developer.rhino3d.com/api/rhinocommon/rhino.display.viewcapturesettings.colormode
If it has to be achieved through running a C# script, I am happy to do that!
Sounds like you’re after the OutputColor property.
https://developer.rhino3d.com/api/rhinocommon/rhino.display.viewcapturesettings/outputcolor
hi Travis, yes. I would really appreciate if there is a sample code that achieves similar function that I can reference to… I have done some Python but don’t have too much experience with C#
Where is your script? These API’s work with both languages.
Hi Travis, thanks for the quick response.
I don’t have a script started yet for this effort. In fact, I am not sure how to start.
I have seen the [rhino.display.viewcapturesettings/outputcolor] you shared with me before.
But my experience outside Rhinoscriptsyntax is almost none and it’s not too helpful for me.
Would you please kindly point me to something that I can take a look at.
Thanks again.
I see, sorry I thought you were suggesting that you might have had a start to an existing python script.
You can find scripting examples here for Python and C#. I would highly suggest using the examples provided to help get you started with scripting.
More specifically here’s a basic example of capturing a view to a black and white image file.
import System
from System.Drawing import Imaging
from System.Environment import GetFolderPath, SpecialFolder
import Rhino
import Rhino.Display as display
def capture_black_and_white_view():
    view = Rhino.RhinoDoc.ActiveDoc.Views.ActiveView
    if view is None:
        return Rhino.Commands.Result.Cancel
    vcs = display.ViewCaptureSettings(view, view.Size, 72)
    vcs.OutputColor = display.ViewCaptureSettings.ColorMode.BlackAndWhite
    vcs.RasterMode = True
    vcs.SetModelScaleToFit(False)
    bitmap = display.ViewCapture.CaptureToBitmap(vcs)
    if bitmap is None:
    desktop_path = GetFolderPath(SpecialFolder.Desktop)
    output_file_path = System.IO.Path.Combine(desktop_path, "ViewCapture_BW.png")
    bitmap.Save(output_file_path, Imaging.ImageFormat.Png)
    bitmap.Dispose()
    return Rhino.Commands.Result.Success
I’ve also created a ticket to add the Output Color option to the command.
https://mcneel.myjetbrains.com/youtrack/issue/RH-85006/ViewCaptureToFile-Add-OutputColor-support
Also note that you can use the Print command and save as a black and white image with more options than what the ViewCaptureToFile command offers but not as easy to create macros with.
I really appreciate that!
Quick question: if I run this code, would it affect the color output setting of my regular rhino command “ViewCapturetoFile” ?
No, this isn’t connected to the command in any way.
Hi Travis, do you happen to know how I can get the script to capture the color and lineweight of printdisplay?
Have you tried adjusting the Output Color? It can be set to Display, Print, or Black and White.
