Change size of preview: point-node
A bit of a silly question.
But is it possible to change the ‘preview’ size of a node?
I would like to make them a bit smaller.
(because when there are a lot of points and you zoom out its get very buzy…)
Any suggestions?
Thanks!
:slight_smile:
you can change it to dot instead (in Display > Preview Point Flavour)
Check out the Symbol Display in the Display / Preview tab, you can set all sorts of display styles and sizes for points.
Perfect, thanks! :+1:
