Change point display size on a per layer basis
I would like to change the display size for points on a particular layer, is this possible? The reason is that I want to use them to denote certain origin points, so displaying them bigger, while maintaining their snapping capability would be ideal. But it appears there is no way to change a point’s size from within the properties panel (lineweight doesn’t affect points with Printdisplay enabled).
AFAIK, it’s a display related setting only. So what you can do is make a custom display setting and assign the objects to use that display setting:
Would be nice if this was an object property though.
But it works for now.
For anyone interested, you can change display modes in the properties panel for selected objects. There you can set them to display in a different display mode (if that wasn’t obvious):
