Change Path Tracing Sample by Code
Is there a way to change the passes by code?
By default is 50, and I would like to increase it. I saw there is an option in Document Properties, but I can not access also.
Any idea?
Thanks,
Rafa
@nathanletwory - is this something you can help with?
These settings are document properties, you can set them as follows:
import scriptcontext as sc
d = sc.doc.RenderSettings.UserDictionary
d["UseDocumentSamples"] = True
d["Samples"] = 42
GUI doesn’t always update automatically, but closing the dialog and rendering panel, then reopening them will show the updated settings.
