Change number of around faces on multipipe tool
Hello, is there any way to do this? Currently I get 4 around faces on the pipes which looks a bit crap and I think it would look a lot better if I could have 6 around faces. Can this be changed any way?
Hi @vanastarr
You can apply the SubDivide command to any SubD object to increase the face count.
It is also planned to add a future option to Multipipe to control just the number of around divisions separately.
Thanks. So obviously a subD circle is never a “true” circle but 6-8 faces looks way better than 4. If I subdivide the 4 around faces to 8 it still looks bad (like the topology doesn’t change as expected as if you increased the around face count. I did try this.
