Would it be possible to build my solution in Visual Studio using an earlier version of .NET? I have set it up for 4.5 but now I would like to use the components in RH5, so 4.0. I tried changing this in the properties, but it resulted in many errors.
Gr,
Peter
Hi @peter18,
If your plug-in project references Rhino 6 assemblies, then your project will need to target .NET Framework 4.5.
If you want your project to build a plug-in that runs in Rhino 5, then modify the references to use those assemblies provided by Rhino 5.
Does this help?
– Dale
Hi @dale,
Yes that does make it more clear. I feel I should have though of that myself. I will give it a try,
Thx,
