Change native ifc type for VA objects
I’m wondering if it’s possible to change the ifc type for native VA objects.
For example, I create a baseboard using VA Beam, but I’d like to change it to ifc Covering. Currently, if I go to the ifc panel, I can’t change or assign it, except for objects created in Rhino. Is there a solution?
I think this possibility could be a good feature, giving maximum flexibility to the ifc types mapping of any entities (RH or VA)
Thank you
Hi @fn_a , thanks for this suggestion. Right now the VisualARQ objects can’t get a different IfcType than the object type they are except for the “Element” object.
We have plans to provide more flexibility in this regard for VisualARQ objects as you can do with the Element or the Rhino geometry.
