Hello:
Here is the script to change multiple blocks to furnitures.
It first creates the furniture style with the same name of the block then creates the furniture instance.
vaChangeBlocksToFurniture.py (921 Bytes)
Hello:
Hello Ahmet, sorry for this newbie question - but how do I install this script into Rhino?
I managed to run the script, but I have to rerun it each time.
Also, the furniture doesn’t seem to appear in PLAN view :s
I think there is something about the ‘Hidden’ display mode. If you try a different display mode, it shows without a problem.
Hi @mahmoud.ramdane,
Can you check that the Plan Visibility for the object is not set to Hidden?
If this doesn’t fix the problem please send the model to visualarq@asuni.com
Kind regards
