snabela
(Alexander Schiftner)
April 13, 2014, 9:11pm
1
how do I change lighting for a single object to no lighting in a display conduit (channel SC_DRAWOBJECT)? I have tried
m_pDisplayAttrs->m_eLightingScheme = LS_NONE;
and
m_pChannelAttrs->m_eLightingScheme = LS_NONE;
but both didn’t help. I’m using m_pVP->DrawFalseColorMesh to display analysis results, for which lighting should be switched off.
jeff
(Jeff LaSor)
April 14, 2014, 3:53pm
3
Because of the way the multipass rendering pipeline works, you cannot disable lighting for individual objects simply by changing the lighting scheme.
Instead, this is controlled at the material level for each object. In your SC_DRAWOBJECT conduit you would do something like the following:
CDisplayPipelineMaterial* dspMat = m_pDisplayAttrs->m_pMaterial;
if ( (dspMat != NULL) && TURN_OFF_LIGHTING_FOR_THIS_OBJECT )
dspMat->m_FrontMaterial.m_bDisableLighting = true;
dspMat->m_BackMaterial.m_bDisableLighting = true;
The “TURN_OFF_LIGHTING_FOR_THIS_OBJECT” is something you need to determine (and it already sounds like you have this in place). Note: I disable both the front face and back face materials since some display modes can override backface materials.
Let me know if you have any questions.
Thanks,
-Jeff
snabela
April 14, 2014, 7:28pm
4
Dear Jeff,
many thanks, work like a charm!
Alex
