(8.0.22347.14305, 2022-12-13)
Change layer is broken in that new layers are not visible in the change layer popup.
- create a couple of new layers in the layer panel
- try to change the layer of an object to one of these layers by calling the “change layer” command.
- in the popup “Layers for objects” that appears, the new layers are not visible.
You can change the layer of the object by calling its properties, and change its layer there.
Even after this, the ‘change layers’ popup doesn’t pick this up.
A restart fixes it…
cheers
rabbit
