Hello there, I am a woodworker and am designing some drawers. I have finished the design, but now need them to be 8mm wider.
I am wondering if there is away to make the draw wider without changing any of the finger joint dimensions? If I use the scale tool for example this will change those dimensions.
The way I ended up doing it was using the gumball to move the side pieces 4mm away in each direction, then using the split tool to split all the front facing pieces. I then used the gumball again to move these split pieces 4mm away from each other. I then selected the edges of the split pieces and used the move tool to snap them back into the center.
Any suggestions for a better way of doing this would be greatly appreciated. Thanks
