Change c plane
when i go, set c plane origin / set c plane by 3 points and then go, previous c plane. it doesn’t go back to the previous c plane.
you can use named cplanes to quickly switch between them
what does this mean ? i didn’t withdraw anything ?
Hi @anajob,
Each viewport saves a list of previously used construction planes. When undoing (or restoring) a previously used construction plane, make sure you have the correct viewport active before initiating the CPlane command.
– Dale
I posted a response and canceled it.
