Change BlockManager settings programmatically
I would like to ask if it is possible to programmatically change the settings of the BlockManager. We work with a pretty extensive block-based version control system in our engineering process. For this to work correctly we need to make sure that this “embedded and linked blocks should” settings is set to prompt or always for every colleagues rhino installation.
We already work with loading a standard rhino-settings.ini but I was not able to find these blockmanager settings in there. Curious if this is accessible through the ini or using Rhino Common.
Thanks in advance,
-Jirri
Hi @Jirri_van_den_Bos,
No, there currently is no way to access this property with RhinoCommon. I’ve logged a ticket so we can expose this.
Note, this is a per-document property and not an application setting.
– Dale
Hi Dale,
Thanks a lot for picking this up so quickly! I’ll keep an eye on the ticket
-Jirri
