hi,
is there an event in Rhinocommon which raises when Doc.Views.ActiveView is changed by the user?
thanks
hi,
thanks
Subscribe to the event Rhino.Display.RhinoView.SetActive.
thanks Nathan, I tryed with that event but seems that it is raised only when the user is “getting out” from a detail view, not even when double clicking on it to enter in “model space”, neither navigating between layouts.
What I am looking for is an I an event to get raised when the user navigates from layout to layout (pageView to pageView)
thanks
I’ll have to defer answering that to @dale.
This seems to work for me:
public class TestAitorleceta : Command
private bool m_enabled;
public override string EnglishName => "TestAitorleceta";
if (m_enabled)
RhinoView.SetActive -= OnSetActiveViewEventHandler;
else
RhinoView.SetActive += OnSetActiveViewEventHandler;
m_enabled = !m_enabled;
return Result.Success;
/// <summary>
/// RhinoView.SetActive event handler
/// </summary>
public static void OnSetActiveViewEventHandler(object sender, ViewEventArgs e)
RhinoApp.WriteLine("Active view set to \"{0}\"", e.View.ActiveViewport.Name);
– Dale
