Is there a way to chamfer the surfaces with 0 distance, to create a close box?
chamf_surf.3dm (3.2 MB)
i think i found the solution. Its the connectsrf command
The easiest solution would be to untrim or extend all surfaces, join into a solid using the Create solid command in the Solid Tools Tab and then if required _ShrinkTrimmedSurface. Then add whatever chamfers you want.
If you want to do this in Grasshopper you need to use an evaluate surface component to get the plane for each surface otherwise the scaling is not correct.
Are you sure?
I think grasshopper scale command work on object plane by default.
Actually you’re right since your surfaces are planar the evaluate surface component is not required.
Actually, the easiest I can think of for this specific example is to run BoundingBox.
boundingbox create a box. Not suitable for the second example.
Or not?
Right - only your first example.
