Chamfer edges Rhino
Why chamfer edge doesnt work on oblique brep surfaces? Aim is not to use Grasshopper
Post a file with your object chamfered and before chamfered so someone can take a look.
Chamfer.3dm (166.9 KB)
The command works fine but the slopes on your object are not identical on all four sides.
You’d need to have the same angle or distance on all four sides to avoid this little edge.
Chamfer.3dm (151.3 KB)
oh my bad. Thanks for the insight.
