The Chair 44 monotile was recently discovered, which allows 3D space to be tiled by a single tile, and only allows for an aperiodic tiling. The tile is the simple chair shape, a 2x2x2 cube with one corner removed, with a system of face colourings to prevent periodic tilings, which are otherwise possible.
A recent paper by Felix Flicker (https://arxiv.org/pdf/2609.23783) provided a simpler colouring system, and gave a diagram (Figure 4c) which uses a surface texturing to enforce the matching rules.
There are ‘male’ and ‘female’ faces, which match one another, and ‘hermaphrodite’ faces that match only other hermaphrodite faces. I have used this to produce a grasshopper definition for actual physical tiles.
Note that both the male and female faces extend both above and below the surface of the face, which prevents the female faces from matching other female faces (although this would leave a cavity, which would not constitute a proper space-filling tiling).
The hermaphrodite faces could simply be blank surfaces, but I have used a pattern of eight cones and conical depressions.
When a chair is to be added to the growing cluster, it approaches the cluster radially along a main diagonal, i.e. at an angle of atan (1/sqrt(2)) or 35 degrees to each axis. By making all the male, female and hermaphrodite cones and depressions have this angle, the new chair piece is able to slide into place against all three impinging surfaces without interference. By making the angle of the cones slightly larger than 35 degrees, i.e. about 39 degrees, the new chair clicks into place with a little force, (like Lego) and the model becomes stable and self sustaining. The actual angle was a question of much experiment and depends on the characteristics of the plastic and the 3D printing process. Felix’s diagram is much too steep to have been actually assembled.
The reason that I gave the hermaphrodite faces a 3D texture was to prevent the new chair from being added by sliding it into place along these faces, which would have prevented the ‘click’ mechanism from being so effective.
Note that the tiling pattern really can tile the whole of space, and not just seven-eighths of it, since the missing cube can be filled in recursively with smaller and smaller copies of the tiling, other than filling the missing corner of the smallest chair (where the devil lives).
The tiles can be clicked together in other shapes, but all of these are subsets of the full chair pattern:
Here is my grasshopper definition for the unit chair piece.
Chair3.2.gh (31.0 KB)
and the resulting STL file
Chair3.2.stl (1.5 MB)
Here is the 3mf file that I used for actual printing.
Chair3.2.3mf (548.3 KB)
The tiles are 40mm on a side. I am not sure how well it would work if they were smaller; this would depend on the accuracy of your printer. It might be necessary to go back to the grasshopper definition to adjust the height of the cones to ensure the correct degree of ‘clickiness’. The angle of the cones must be more than 35.26 degrees to have any hope of holding, and I know that 45 degrees is too much, but there is some room for experiment.
I printed the tiles with the missing cube facing downwards. For an extrusion printer like mine, support material is needed, but this comes off easily. The print takes about an hour per tile, i.e. more than eight hours for a set of nine. Making them smaller could be much faster, but I have not experimented with that yet.
Cheers,
Bob
