Chain select points along U or V [solved]
is there a way to do this without _lasso etc ?
nevermind! SelU/V does the trick !
Hello - also, if the setting in Options > Mouse > ‘Make contriol polygon pickable’ is checked, a double-click on the control polygon will select that entire row.
oh that’s actually super helpful @pascal !!!
does it always select in U only?
thank you!
Edit: oh its viewport angle dependent …… very cool !!!
