Hello
Why does the chain (edge loop) appear to float above the surface ; is this a bug?
Hello
Could you please share this 3dm file? Thank you.
Yes
chain.3dm (11.5 MB)
It seems to be caused by the object being too small. The edge length of this object is about 0.01 units. If you scale the object up by 10 times, the issue you mentioned earlier should no longer occur.
Thank you. Yes, you are right. It works fine in Rhino 7, and I have logged this issue with our development engineers.
RH-96835 Unwrap: Chain curve displays offset from mesh
