CFD meshing
Hi everyone,
I am simulation engineer. I generally use Openfoam for my analysis and due to internal needs from my current workplace I am in need to use rhino for meshing. I did see some tutorials on Youtube but I could not get a solid start. Any direction or links which shows how to carry out meshing in rhino would be much appreciated.
What Kind of Data do you get and want to Mesh?
What Problems are you facing?
I guess the Tutorials did Help you to get a Mesh? But you dont Like it?
Can you explain more what the mesh is used for? I have limited experience meshing in Rhino for CFD, so may be able to help.
If the mesh is going to be used directly as discretization grid of a flow domain, only very simple geometry will work; Rhino makes meshes that are used for visualization/rendering, not for simulation and other packages are way better at making simulation grids. On the other hand, if the mesh is to be used as the solid boundary in for example snappyHexMesh, the meshes coming from Rhino should - if made with sufficient resolution - work in OpenFOAM.
i assume you could check grasshopper for remeshing. Rhino itself has Quadremesh which could be interesting for some applications, but grasshopper might offer more. triremesh was introduced some years ago which might be also quite useful. if its just static and it must do nothing other than be a collision object any mesh would do i guess.
One plugin for Rhino.Grasshopper is Butterfly : https://www.youtube.com/watch?v=6meHDZMJp-I
Tool Ladybug Tools | Butterfly
Forum for Butterfly: https://discourse.ladybug.tools/
Hi @menno apologise for the delay in response. Yes I use open foam and want to create snappy hex mesh
Great, in that case - if your model is closed - you should be able to get a dense enough mesh with Rhino’s mesh command that, when exported to a file that snappyHexMesh can read (STL?), will allow snappyHexMesh to use it as a background solid to snap onto.
Always check that your mesh is closed. There are isolated cases where closed models give meshes that are not closed.
hi Menno,
thank you so much for your guidance and yes it worked
