Hi all,
I’ve drawn some breps that are stacked on top of each other and want to cull the overlapping surfaces that make up the shared “ceiling/floor”. It’s all part of a much larger definition, so this is just a simplified example. I’ve managed to single out these surfaces (four in the attached example) and now I want to use their centroids as a culling pattern.
For some reason, this has proved impossible using equality, equality with tolerance, similarity, etc, etc. I get values that match perfectly on screen, but no matter how I tinker with tolerances, GH won’t treat them as identical.
To illustrate the issue, in the attached file I drew small spheres around the four centroids that I want to use for the culling, and larger spheres around the list of centroids for all surfaces that I want to cull from. Shouldn’t ShapeIn now recognise the four smaller spheres inside the larger spheres (instead of recognising just one of them)?
I’m clearly missing something here - what am I doing wrong?
Thanks
191112_gh-question.gh (47.5 KB)
