Is it possible to center a textentity?
I can’t set align anywhere and getboudingbox does only return the align point…
Thank you.
Jordy
Thank you.
Jordy
Center on what? I think I need more information.
– D
Hi Jordy,
Not sure if this helps but I found in python it can be done like so:
import scriptcontext
import Rhino
obj = rs.SelectedObjects()[0]
rhobj = rs.coerceguid(obj)
rhgeom = rs.coercegeometry(obj)
rhgeom.Justification = Rhino.Geometry.TextJustification.MiddleCenter
scriptcontext.doc.Objects.Replace(rhobj,rhgeom)
http://4.rhino3d.com/5/rhinocommon/?topic=html/P_Rhino_Geometry_TextEntity_Justification.htm
HTH
-Willem
@Willem Exactly what I was looking for.
Just couldnt find the Allign part anywhere. Thought it would be under rhgeom.allign or something.
Thank you.
@dale What I have is a rectangle and the text needs to be in the center-center of this rectangle. I was able to center-center the reference point of the textentity but could not change the allignment of it.
Here is (another) sample if anyone is interested.
https://github.com/dalefugier/SampleCsCommands/blob/master/SampleCsText.cs
