I am trying to build a triangular ceiling grid and extrusion based on a point attractor. I have succeeded with a simple extrusion, however, when I add an offest modifier it fails. Any hint where there could be the problem?
All the Best,
Christophatractor triangles 1.gh (16.1 KB)
I have now included a flatten “command” to the output. It might now work - but I do not really understand why. Might need some tutorials for data trees I guess.
“Graft” also works here. Mind the path matching. If you use Offset Curve, it will add the branch path index one more at the end…so I use Shift Pathsafter that.
atractor triangles 1_re.gh (9.2 KB)
