I upload a situation where Parallel Computing seems to create a problem:
if I enable the Parallel Computing my solver stop working.
unnamed.gh (120.4 KB)
thanks for your support!
Make sure both input data is grafted. Parallel still takes longer, but that’s a different problem.
(removed pic).
Edit: Hm, but that’s perhaps not waht you want to do. It would have been a good idea if you had explained that Rhino hangs of using parallel. Rhino crashed.
// Rolf
did I raise this issue in the right place?
Are you running the latest service release of Rhino? We fixed a few threading issues with grasshopper in recent service releases.
I thinks so, this is the version: 6.8.18240.20051, 08/28/2018
Rhino 6.10… here.
// Rolf
I have the same bug here. When using parallel computing with CCX it gives wrong result. The solution for that is to turn off parallel computing. Using Rhino Version 6 SR16 (6.16.19190.7001, 07/09/2019)
Hihi!! I had a kind of similar problem! When parallel computing is turned on, it works… but something goes wrong with the data structure. Turning off parallel computing solves this.
