I try to change the solid catamaran hull model as in the picture.
Tell me the easiest way to change the bow shape angle, please. The command “SolidPtOn” gives me unpredictable results
I can redesign it but it will take too much time because of the multi-crossing surfaces. Any thoughts welcome
Cage edit maybe?
Explode the polysurface, and push & pull control points of the surfaces separately (if the surface is “optimized” of course)
please post your file and make a sktech (a few lines indicating how you want the hull to look like). if all the edges should end at the red line you might have to rebuild the surfaces, but nothing out of the ordinary job of 2-3 minutes…
Ingeniously! Solved.Many thx
