Casement Double With Handles Stuck with Offset
I can’t get this window type to insert in the wall with proper alignment. It offsets by a significant amount no matter how I adjust the window-wall alignment for either window or frame, either in the styles editor or as an override. In this case the window-frame alignment is set to exterior. Actually it appears this happens whenever the frame depth is deepened to the 7" I am using. I’ve tried the double and single versions, and each have the same behaviour.
Hi @djhg,
Please, could you send me the file?
Thanks Alfonso:
CasementDoubleWithHandlesOffset.3dm (742.8 KB)
Perfect! I’ll report it
