I noticed that the preview window of the '_ViewCaptureToFile tool shows oversized UV indicators. They are even bigger than the actual UV indicators in the viewport.
Yes, some graphical elements are shown much bigger in the preview window and that’s confusing for the user as to what to expect in the output image.
Another issue is that the preview of the viewport capturing in the tiny preview window does not show the actual area of the captured window when a custom resolution is used. The Safe frame remains to the extra wide ratio of my wide viewport, even though I set my custom capture resolution to 1080 with a scale of 2 (because Rhino still lacks a 4K option in the dropdown list). I reported this for Rhino 7 several years ago and most likely there is a YT issue somewhere in your list.
Rhino needs a better way to show the captured area inside the viewport. The “Safe frame” is quite limiting. Long time ago I suggested to allow an alternative to the 3 rectangular frames that’s basically 4 L-shaped corners like 20x20 pixels big, in order to make the viewport much more convenient to work.
When I try to run Render > Safe frame settings, Rhino 9 BETA does nothing. Is that a bug? It happens only when I keep the right sidebar in auto-hide mode. However, if I press the “Toggle the right sidebar visibility” icon on the bottom right corner, the settings for the “Safe frame” are properly shown here.
Also, there is one visual inconsistency that’s also shared between Rhino 7 and Rhino 9 BETA. When I click on any of the top text menus, the very bottom toolbar disappears. It’s a bit distracting. Ideally, the bottom toolbar should remain visible, because I see no reason to lose valuable information when I reach for the text menu.
Please try and make individual posts for separate issues. It is going to makes this really difficult to work thru these together as one post. Here are the 4 issues so far from that last post:
- Oversized UV/graphical indicators in the capture preview — The
_ViewCaptureToFilepreview window renders UV indicators (and other graphical elements like ShowDir markers) much larger than they appear in the viewport. Notably, the capture output itself is at the correct scale, so this is purely a preview-rendering scaling bug. - Preview safe frame ignores custom resolution/aspect ratio — When a custom capture resolution is set (e.g. 1080 at scale 2), the preview window’s safe frame keeps the viewport’s wide aspect ratio instead of reflecting the actual captured area. (Reporter notes this was already filed against Rhino 7 years ago, so a YT issue may exist.)
- “Safe frame settings” command does nothing in auto-hide sidebar mode — In Rhino 9 Beta, running
Render > Safe frame settingsdoes nothing when the right sidebar is in auto-hide mode; it only works after toggling the sidebar to visible. Likely a real bug. - Bottom toolbar disappears when opening top text menus — A visual inconsistency present in both Rhino 7 and Rhino 9 Beta: clicking any top menu hides the very bottom toolbar.
Item 1 and 2 have been reported. I can recreate those issues.
Item 3 in This seems to work one time, then it stops popping out. So, I think I was able to recreate this one.
Item 4, I cannot recreate. Can you show me a capture of what you are seeing?
There are also 2 feature requests sprinkled in there:
- 4K option in the resolution dropdown
- alternative safe-frame style using four small L-shaped corner brackets instead of full rectangular frames.
I can report those also as enhancement requests.
I will reply in more detail tomorrow when I have some free time.
With regards to your request, here is a quick video capture of both, Rhino 7 and Rhino 9 BETA. Both exhibit this behaviour when I click on the top text menus: the bottom toolbar disappears.
Some of the sub-menus trigger a tooltip to the bottom, where the toolbar was previously located. I find these tooltips quite unusable, because the text menus are on the top while the tooltips are at the very bottom. Plus, they double what was already selected by the mouse pointer hovering over the text menus.
The hide/unhide of the bottom toolbar is distracting to my eyes due to the contrasty active buttons.
Interestingly, some of the text commands will not trigger their respective bottom bar tooltip, such like Tools > Grasshopper and Tools > License manager. In this case, hiding the bottom toolbar is even more unnecessary.
Do you want me to make 4 new individual topics, or 4 individual posts in this topic?
I think I got all the issues reported, so we may be OK. Just something to think about in the future. Keeping them separate helps when discussing details etc…
This is the behavior in 7, 8 and 9. At this point there is no way to set this as an option. I can report it, so they may be able to add it in the future.
It would be great if this could be turned off in Rhino 9 RH12 or Rhino 10.
When this hiding of the bottom bar triggers upon reaching the top text menus, my attention is grabbed by the brief flashing and I’m forced to check all of my active buttons at the bottom (Ortho, History, Osnap etc) to see if they are properly selected.
