I have this method that captures an image and saves it in a location:
public void SaveImage()
string ImageName = @"C:\";
var doc = Rhino.RhinoDoc.ActiveDoc;
var view = doc.Views.ActiveView;
var view_capture = new ViewCapture
Width = view.ActiveViewport.Size.Width,
Height = view.ActiveViewport.Size.Height,
ScaleScreenItems = false,
DrawAxes = false,
DrawGrid = false,
DrawGridAxes = false,
TransparentBackground = true
var bitmap = view_capture.CaptureToBitmap(view);
if (null != bitmap)
bitmap.Save(ImageName, System.Drawing.Imaging.ImageFormat.Png);
bitmap.Dispose();
This method works beautifully, but it also takes a little time to execute this method, it is only a little bit but it affects the following functions.
My solution is to run this method within a task: Task.Run(() => saveMat.SaveImage());
Runing with Task, popup “Exception Error”:
I’m not able to find out where this error comes from and why, any ideas?
